Hi to all, I’m new to lightburn so maybe this is stupid question but i have tried all fill and optimize options
and i still cant get what i need.
I’m not so good at explaining things but i’ll try(GIF will explain)
I am using an eleksmaker chinese clone with GRBL controller and diode laser so my cut/fill speeds are 500-2000mm/min. So basically i want to be able to fill shapes in one pass of the laser as the 60000 speed example shows but with speeds 500-2000, the 1000 speed example show what i got but dont want. Hope you can understand me and thanx for answers.
https://drive.google.com/file/d/1sRy9W3l1I0ycQvR31ODctg04TtTp1W_F/view?usp=sharing
Hi Daniel, select the ‘optimize cut path’ in your ‘laser’ window.
In the ‘cuts/layers’ window select ‘fill all shapes at once’.
Hopefully that’s what you’re after.
