Is this what you were looking for? Coming in 2 parts…
weashby@penguin:~$ dmesg
[ 0.000000] Linux version 4.19.113-08528-g5803a1c7e9f9 (chrome-bot@chromeos-ci-full-info-us-central2-c-x32-7-nv15) (Chromium OS 11.0_pre383902_p20200312-r7 clang version 11.0.0 (/var/cache/chromeos-cache/distfiles/host/egit-src/llvm-project e21b39a86dd6e8d1a5a5fe7e0286f8570732834d)) #1 SMP PREEMPT Thu Apr 2 15:21:14 PDT 2020
[ 0.000000] Command line: pci=noacpi reboot=k panic=-1 snd_intel8x0.inside_vm=1 snd_intel8x0.ac97_clock=48000 root=/dev/pmem0 ro rootflags=dax
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
[ 0.000000] x86/fpu: xstate_offset[3]: 576, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 640, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using ‘compacted’ format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000200000-0x00000000b24fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: ChromiumOS crosvm, BIOS 0
[ 0.000000] Hypervisor detected: KVM
[ 0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
[ 0.000001] kvm-clock: cpu 0, msr 4f0a3001, primary cpu clock
[ 0.000001] kvm-clock: using sched offset of 280984081 cycles
[ 0.000036] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[ 0.000040] tsc: Initial usec timer 275614
[ 0.000041] tsc: Detected 1094.400 MHz processor
[ 0.000451] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000454] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000457] last_pfn = 0xb2500 max_arch_pfn = 0x400000000
[ 0.000550] MTRR default type: write-back
[ 0.000551] MTRR fixed ranges disabled:
[ 0.000553] 00000-FFFFF uncachable
[ 0.000554] MTRR variable ranges enabled:
[ 0.000555] 0 base 00D0000000 mask 7FF0000000 uncachable
[ 0.000556] 1 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000557] 2 disabled
[ 0.000557] 3 disabled
[ 0.000558] 4 disabled
[ 0.000559] 5 disabled
[ 0.000559] 6 disabled
[ 0.000559] 7 disabled
[ 0.000580] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000640] found SMP MP-table at [mem 0x0009fc00-0x0009fc0f]
[ 0.000750] Scanning 1 areas for low memory corruption
[ 0.000894] Using GB pages for direct mapping
[ 0.000898] BRK [0x4f201000, 0x4f201fff] PGTABLE
[ 0.000901] BRK [0x4f202000, 0x4f202fff] PGTABLE
[ 0.000903] BRK [0x4f203000, 0x4f203fff] PGTABLE
[ 0.000925] BRK [0x4f204000, 0x4f204fff] PGTABLE
[ 0.000928] BRK [0x4f205000, 0x4f205fff] PGTABLE
[ 0.000968] BRK [0x4f206000, 0x4f206fff] PGTABLE
[ 0.001029] ACPI: Early table checksum verification disabled
[ 0.001056] ACPI: RSDP 0x00000000000E0000 000024 (v02 CROSVM)
[ 0.001062] ACPI: XSDT 0x00000000000E01B0 000034 (v01 CROSVM CROSVMDT 00000001 CROS 00000000)
[ 0.001069] ACPI: FACP 0x00000000000E0054 000114 (v06 CROSVM CROSVMDT 00000001 CROS 00000000)
[ 0.001077] ACPI: DSDT 0x00000000000E0024 000030 (v06 CROSVM CROSVMDT 00000001 CROS 00000000)
[ 0.001082] ACPI: APIC 0x00000000000E0168 000048 (v05 CROSVM CROSVMDT 00000001 CROS 00000000)
[ 0.001094] ACPI: Local APIC address 0xfee00000
[ 0.001216] Zone ranges:
[ 0.001219] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.001221] DMA32 [mem 0x0000000001000000-0x00000000b24fffff]
[ 0.001223] Normal empty
[ 0.001224] Device empty
[ 0.001226] Movable zone start for each node
[ 0.001227] Early memory node ranges
[ 0.001229] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.001230] node 0: [mem 0x0000000000200000-0x00000000b24fffff]
[ 0.004280] Zeroed struct page in unavailable ranges: 23650 pages
[ 0.004283] Initmem setup node 0 [mem 0x0000000000001000-0x00000000b24fffff]
[ 0.004287] On node 0 totalpages: 730014
[ 0.004288] DMA zone: 59 pages used for memmap
[ 0.004289] DMA zone: 22 pages reserved
[ 0.004290] DMA zone: 3742 pages, LIFO batch:0
[ 0.004753] DMA32 zone: 11348 pages used for memmap
[ 0.004754] DMA32 zone: 726272 pages, LIFO batch:63
[ 0.104144] ACPI: Local APIC address 0xfee00000
[ 0.104161] Using ACPI for processor (LAPIC) configuration information
[ 0.104168] Intel MultiProcessor Specification v1.4
[ 0.104172] MPTABLE: OEM ID: CROSVM
[ 0.104174] MPTABLE: Product ID: 000000000000
[ 0.104175] MPTABLE: APIC at: 0xFEE00000
[ 0.104240] IOAPIC[0]: apic_id 3, version 17, address 0xfec00000, GSI 0-23
[ 0.104244] Processors: 2
[ 0.104247] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.104292] [mem 0xb2500000-0xffffffff] available for PCI devices
[ 0.104295] Booting paravirtualized kernel on KVM
[ 0.104298] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.221250] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:2 nr_node_ids:1
[ 0.225647] percpu: Embedded 40 pages/cpu s131368 r0 d32472 u1048576
[ 0.225659] pcpu-alloc: s131368 r0 d32472 u1048576 alloc=1*2097152
[ 0.225661] pcpu-alloc: [0] 0 1
[ 0.225689] KVM setup async PF for cpu 0
[ 0.225702] kvm-stealtime: cpu 0, msr af214fc0
[ 0.225708] Built 1 zonelists, mobility grouping on. Total pages: 718585
[ 0.225712] Kernel command line: pci=noacpi reboot=k panic=-1 snd_intel8x0.inside_vm=1 snd_intel8x0.ac97_clock=48000 root=/dev/pmem0 ro rootflags=dax
[ 0.233976] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.238525] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.250380] Memory: 2840680K/2920056K available (12312K kernel code, 740K rwdata, 2216K rodata, 928K init, 1484K bss, 79376K reserved, 0K cma-reserved)
[ 0.250621] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.250655] Kernel/User page tables isolation: enabled
[ 0.264094] rcu: Preemptible hierarchical RCU implementation.
[ 0.264100] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2.
[ 0.264102] Tasks RCU enabled.
[ 0.264104] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.264142] NR_IRQS: 4352, nr_irqs: 440, preallocated irqs: 16
[ 0.264578] random: get_random_bytes called from start_kernel+0x1f3/0x382 with crng_init=0
[ 0.687175] console [ttyS0] enabled
[ 0.689953] ACPI: Core revision 20180810
[ 0.693459] ACPI: setting ELCR to 0020 (from 0000)
[ 0.702842] APIC: Switch to symmetric I/O mode setup
[ 0.707339] x2apic enabled
[ 0.710414] Switched APIC routing to physical x2apic.
[ 0.716894] …TIMER: vector=0x30 apic1=-1 pin1=0 apic2=-1 pin2=-1
[ 0.721915] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0xfc66f4fc7c, max_idle_ns: 440795224246 ns
[ 0.729838] Calibrating delay loop (skipped) preset value… 2188.80 BogoMIPS (lpj=1094400)
[ 0.740847] pid_max: default: 32768 minimum: 301
[ 0.744923] Security Framework initialized
[ 0.747842] Yama: becoming mindful.
[ 0.751917] Chromium OS LSM: enabled
[ 0.751918] SELinux: Initializing.
[ 0.758001] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.767985] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.775080] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.778840] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.783847] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.795851] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.799840] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.806843] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.813843] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.836769] Freeing SMP alternatives memory: 36K
[ 0.842077] TSC deadline timer enabled
[ 0.842083] smpboot: CPU0: Intel 06/7a (family: 0x6, model: 0x7a, stepping: 0x1)
[ 0.848948] Performance Events: Goldmont plus events, Intel PMU driver.
[ 0.849851] … version: 2
[ 0.850843] … bit width: 48
[ 0.851852] … generic registers: 4
[ 0.852855] … value mask: 0000ffffffffffff
[ 0.853846] … max period: 000000007fffffff
[ 0.854845] … fixed-purpose events: 3
[ 0.855843] … event mask: 000000070000000f
[ 0.858847] rcu: Hierarchical SRCU implementation.
[ 0.864853] smp: Bringing up secondary CPUs …
[ 0.873893] x86: Booting SMP configuration:
[ 0.874850] … node #0, CPUs: #1
[ 0.452433] kvm-clock: cpu 1, msr 4f0a3041, secondary cpu clock
[ 0.452433] [Firmware Bug]: CPU1: APIC id mismatch. Firmware: 1 APIC: 0
[ 0.889884] KVM setup async PF for cpu 1
[ 0.890836] kvm-stealtime: cpu 1, msr af314fc0
[ 0.896861] smp: Brought up 1 node, 2 CPUs
[ 0.897861] smpboot: Max logical packages: 1
[ 0.898846] smpboot: Total of 2 processors activated (4377.60 BogoMIPS)
[ 0.901187] devtmpfs: initialized
[ 0.904067] x86/mm: Memory block size: 128MB
[ 0.909061] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
