I just downloaded it the other day.
Looks like 0.9.11
after entering the $$ this is what I get back
I don’t have $=32
On a side note.
The windows will not re-dock once I un-dock them.
The window will not turn blue.
Looks like 0.9.11
I don’t have $=32
On a side note.
Ok,
So I found this button that says Current position.
Thought I would try it and see what happens.
Exactly what i want the machine to do.
So I ran the program but now Why am I getting these lines throughout the cut?
You’ll need to use the GRBL-M3 driver in LightBurn, as it appears you’re using a relatively old version of GRBL. You will also want to change $30 to 255 or 1000, and alter the ‘S value max’ setting in the Device Settings window in LightBurn to match it.
My guess is that you’re using 1.0c, which is the default X-Carve firmware. It doesn’t do ‘variable power’ meaning it won’t lower the laser output when cornering, but it’ll work ok for basic engraving.
Thanks for the response.
Do I need to upgrade my GRBL?
If so, whats involved in doing so?
You don’t need to, but you’ll get better results with the laser if you do. If you choose to, use 1.1f or later, and save your machine settings before you do it so they can be restored easily. I’m not sure what’s involved in upgrading the X-Carve controller specifically - usually it’s a small command line tool used to flash the new version of the firmware, but I would check with Inventables to see if they have guidance for this.
There is a specific section of the JTech Documentation covering installation and firmware updating for the X Carve. Scroll mid-way down until you see a section that starts,
Set Up Your Machine – X Carve
Ok, now that you have downloaded Lightburn software, we can get started with the rest of the setup. When you install the Lightburn software, you might see Windows trying to protect you. Click on the bottom “Run Anyway” button to install it. The X Carve has some things you need to change to get it all working, so we will cover it here.
When you first run Lightburn, you should have a quick setup wizard walk you through the setup. Here is what you need to do to get it set up.
Thank you.
Today I feel like I’m finally starting to make some progress.
to update your firmware the simplest way is to download t2 laser and use the trial on it to upgrade the firmware, it does it in seconds, I can assure you though that T2 is nothing light lightburn, Lightburn is the Photoshop of laser software so does take time and patience to learn but once you have it cracked you will never use any other software.
The other way to update is is download the arduino program and do it through that but it sounds like you might have problems doing it that way so i recommend the trial on T2. Its the simplest way to do it
A huge thanks To Jay from J Tech Photonics for walking me through the process.
I now have my firmware updated to 1.1f
Lightburn is now showing real promise.
Although I’m very sure that there will be more questions to follow.
Ok.
So today I trying to learn about the origin.
I go to a specific place, click “set origin”, then move away from the origin. It is my under standing that this should be X Y zero.
I then click “go to origin” the machine goes in a completely different position Not even close to where i expect it to go.
Any thoughts?
Yes, I’ve gone over these instructions several times.
Keep in mind that I don’t have a dedicated laser, my laser is attached to a CNC machine.
My laser will never come from the lower left corner of my machine bed.
My origin will always be the lower left corner of the material that I place on the machine bed.
That being said, When I do that and then call that corner X Y zero, then move away from the zero, then click on the go to origin button, the machine takes off in a completely different direction.
What am I missing?
You have not said much about how you have this CNC setup configured, technically (I can’t see your settings until you share them ), so I would look to the following;
Have you set your machine status reporting to be relative to the workspace origin, not the machine origin ($10=0)?
If your machine uses negative workspace coordinates you’ll need to apply a workspace offset (G10 L2 P1 xx yy).
Could these be issues you are experiencing?
In LightBurn, the zero point of your machine is never altered - On your system, it will always be the front-left corner. Set Origin just records where your machine is when you click that button, and running a job in User Origin mode will start with a jog to that coordinate.
@Rickx
My machine is an X carve with a J Tech 7 watt laser attached.
I don’t know anything about negative workspace.
I simply do not have any problems when I use the CNC and set my X Y zero anywhere I want.
I can jog away from that position, set in a new piece of wood, then tell it to go to X Y Z zero and the machine will move to that position.
OZ,
when I set the the origin, and then move away from it to set another piece of wood.then click the go to origin, th machine goes to a completely different area of the bed.
It doesn’t even try to go to the lower left hand corner of the machine.
It actually wants to go to about the center of the bed and almost all the way to the front edge.
these are my settings
The issue you’re having is likely two parts:
$10 needs to be set to zero, so LightBurn can read the position of the machine in workspace coordinates, not machine coordinates.
The zero point needs to be set to the front-left corner. This is done with a GCode command after homing that shifts the origin by the size of the X and Y travel values. (for example, G10 L2 P1 X-750 Y-750 would be what you’d use if the machine had a 750mm square working area)
Once those two things are done, everything should work as expected.
All of this is covered on this page in the docs: https://github.com/LightBurnSoftware/Documentation/blob/master/CommonGrblSetups.md#common-grbl-setups
And I think the link above that Rick posted to the J-Tech site covers all of it as well, with the exception of the $10 setting.
JVL:
Is this not a positive coordinate machine?
Correct, it is not a positive workspace machine. If you run a homing cycle, and the machine homes to the rear-right corner, and sets that corner as zero, you will need negative coordinates to jog into the work area. This is common for CNC machines, and uncommon for lasers. Read here for a bit more info:
JVL:
(I never use homing as I always home from my work piece)
This is easily most of your trouble in LightBurn. You are using it like CNC software, and it isn’t written to work that way. By zeroing to your workpiece you are eliminating the ability for the software to jog within the machine envelope safely, because you moved it. LightBurn enforces its own soft limits. By changing your zero point, the software can no longer know where the actual bounds of the machine are.
The ‘Click to position’ feature, for example, uses absolute coordinates, relative to the machine zero. If you move the zero, that feature won’t work, and neither will anything else that uses the location of the machine to figure out if you’re going to go out of bounds.
Zero the machine to the front-left corner (the origin) and leave it there. Then use the ‘Set Origin’ feature in the software to set the job location, and ‘User Origin’ mode when running a job. It behaves the same as what you’re used to, but doesn’t require changing the coordinate system.
Good morning OZ,
So to better help me understand.
In the CNC world, my X carve is in positive coordinates.
But in the laser world my X carve is in the negative coordinates.
Is that a true statement?
So I’m out in the shop and going through the directions line by line under the section “other machines”
If you hit the Home button and got error:5 it means homing is disabled on your controller.
I’ve mentioned a couple times now that the $10 setting must be set to zero, but you haven’t confirmed yet if you have done this.
And again, “Set Origin” does not zero the machine, or change anything at all. It simply records the position that the machine reports when you hit that button, and it relies on the $10 setting being correct. When you hit “Set Origin”, LightBurn sends this to the controller:
The controller responds with a status report that includes the current position, reported in either absolute machine coordinates, or relative to the workspace zero. You want the latter, which is what setting $10=0 gives you. If you don’t set that, the ‘Set Origin’ function will record the wrong coordinate, and when you start a job it will go to the wrong place.
If you don’t have homing enabled on your machine, your system is in no particular coordinate space at all.
Normally, an X-Carve has homing switches in the rear right of the machine, and when you home it in CNC mode, it sets that position as zero, which means you get this:
Since that rear-right location is zero, and +X goes right, and +Y goes back, it means you would need to jog in the negative direction to move the head into the usable work area. This is all that is meant by “negative workspace” - The workspace, by default, after homing, is in the negative coordinate area.
With dedicate laser systems, they’re usually set up so that, after homing, the coordinate system looks like this:
The directions are identical, but because the origin is in the front left, the workspace coordinates are all positive numbers.
Homing is the key here. Since your machine doesn’t have it enabled, when you power up, the actual machine origin is going to be wherever the head was when you applied power. Everything else you do from there will be a workspace offset applied to that (completely arbitrary) location. This is why you need to set the machine to report its position relative to the workspace offset, not machine space, because you can’t have a machine space without homing enabled.
