IdahoEric
(Eric Ahrens)
October 7, 2025, 12:34am
1
I received and set up my Roly MK2 today. All seemed good. Lightburn recognizes the machine, jogging and homing work. I set a test piece in the machine and set the height with the tool.
The machine frames properly, but when I press the Fire button, I don’t see any light. The Roly setup data set the Fire power at 2%. I upped it to 10% and still no light.
Does anyone have any suggestions?
MikeyH
(Mike Hembrey)
October 7, 2025, 1:24am
2
I cannot tell from your text, so I have to ask. Did you enable the Fire button in the Device Settings window?
IdahoEric
(Eric Ahrens)
October 7, 2025, 1:41am
3
Yes, it was set up that way by the info that cane with the laser.
MikeyH
(Mike Hembrey)
October 7, 2025, 2:05am
4
Does it fire during framing?
IdahoEric
(Eric Ahrens)
October 7, 2025, 2:28am
5
It does not fire during framing either
Kuth
(Luis Jardim)
October 7, 2025, 7:22am
6
From what I’ve read so far, if the laser doesn’t turn on at all, I would check if the wiring is properly connected/fitted.
IdahoEric
(Eric Ahrens)
October 7, 2025, 3:57pm
7
I tested the laser this morning and the laser works when engraving, just not when I fire or frame. Lightburn is set to fite the laser and have it on during framing.
MikeyH
(Mike Hembrey)
October 7, 2025, 4:20pm
8
This may solve your problem, but it might help understand what the problem is.
In the Console window, turn on the Show All switch. Right-click and select the Clear Console choice.
Make a small square in the workspace, and select it. Speed 500 mm/m and power to 5% . In the Move window, set the Fire button power to .75% .
Click the Frame button, and cancel if you have Continuous Framing turned on.
Click the Run button.
When it finishes, copy and paste the contents of the Console window in a Reply.
Hopefully, the controller, or Lightburn, will tell us why it is not firing while framing.
IdahoEric
(Eric Ahrens)
October 7, 2025, 5:10pm
9
<Idle|MPos:0.000,0.000,0.000|WPos:0.000,0.000,0.000|FS:0,0>
ok
Starting stream
G00 G17 G40 G21 G54
G90
G0 X152.858Y136.85
M3
G1 Y251.15S7.5F500
G1 X261.142
G1 Y136.85
G1 X152.858
M5
G0
G90
Stream completed in 0:54
Starting stream
G00 G17 G40 G21 G54
G90
M4
M7
G0 X261.142Y136.85
Layer C00
G1 X152.858S50F500
G1 Y251.15
G1 X261.142
G1 Y136.85
M9
G1 S0
M5
G90
G0 X205Y370
M2
Stream completed in 0:56
MikeyH
(Mike Hembrey)
October 7, 2025, 5:32pm
10
Turn on Constant Power Mode in the Cuts window and Run it again. Does the laser still turn on?
