No connection to the Laser Machine
Good evening,
I have my Omtech Laser connected to a Mac using LightBurn. I added the device manually, and it shows as “Ready,” but when I try to send a job, I get an error saying there’s a problem sending data to the laser — it might be busy or paused. I also tried connecting through the LightBurn Bridge, but had no luck.
Can someone help me set up my machine properly with LightBurn?
What OMTech laser do you have. Your profile advises an Ortur Laser Master 2.
Does it say ready with USB, Ethernet or both?
Does your laser have a console? If so, to what is the machines IP set? Do you have a lan connection available?
If you set it to your lan, it needs to have it’s IP set to reside on the network. It’s static, so you will likely have to set your router to expect a static device.
If you use the Lightburn, I think it expects the Ruida to be 10.0.3.3 for an IP.
