I just installed the new release this morning. When I send an image to the laser, the head moves according to the pattern, the mA meter registers, but the laser doesn’t fire. When I close Lightburn, I get a good test fire. I uninstalled the new release, re-installed the previous version and now it won’t fire, either. Shut down Lightburn and get a good test fire.
I must be missing something simple, but I can’t figure out what it might be. Running Mini Gerbil on a K40, worked like a peach before I installed the new version.
As per réponse to mrfoameruk on 2/13, I checked my $30 and $32 settings and both are as they should be.
I ran M4, “light instruction” indicator lights up
G0 X0 carriage moves
G1 X10 F600 S200, carriage moves, laser does not fire
M5 “light instruction” indicator turns off.
I would check with AwesomeTech - if there’s an indicator on the board that’s lighting when you use M4, it means that LightBurn is working as intended, and there’s possibly a loose wire or other board issue that coincidentally happened when you updated.
