No laser framing
I swapped from using a Mac to using windows11 now I can’t see the laser when framing. I’ve tried holding shift while hitting frame, I’ve checked to make sure it’s enabled but nothing. I used to could frame without hitting shift or messing with any settings. Also my ortur lm3 showed up in find my laser as grbl-3
Means nothing. Use GRBL for your device type.
Did you copy over your LBDEV file or use the new Bundles feature of LB1.7?
I just downloaded lightburn like I did for the trial period then put in my g code, it’s running on 1.7.01
It’s not letting me change to grbl. Will it affect anything being the other?
I believe if you set your S-value max to 1000 you solve your laser frame power.
After change your current device to GRBL or setup a new one as GRBL type.
Thanks, I changed it to grbl but didn’t rename it so it confused me a bit
