No Machine Settings in Edit menu
Hello, I have just managed to enable my omtech k40+ board to use with lightburn.
The instructions from the board manufacturer are that I should manually add the board to lightburn, which I have done to the point of having it “work”, as it is able to control laser movement, etc. I do have periodic Alarms of different types which I am working on resolving at the hardware level.
What I don’t have is a Machine Settings selection on the edit menu. How can I get the machine settins so I can better work on the hardware? Thanks. Michael.
If this is the K40+ board I assume it’s running Smoothieware. If so, you won’t have a Machine Settings menu item because the configuration is not done that way.
Typically configuration changes are done in the config.txt file on the SD card.
There are also Console commands that can be used to read and set configurations. You can read about those here:
console-commands [smoothieware.org]
