No Power in Lightburn with Sculpfun S9
Hi,
I have a problem. Coming from OLM2, I bought a new Sculpfun S9.
In LaserGRBL it burns as expected - in Lightburn there is no Power.
Drawing a small image, Circle or whatever, assigning 3000/50%, starting: Lightburn moves to the point, turns on light, moves the image, but strength is not enough to burn. Changing to 100% or other values make no difference.
Where should I look?
  1. Make sure that you are set for mm/min and not mm/s or other
  2. Check value of S Value Max in Device Settings. Make it equal to value from $30 in Machine Settings
If you checked PY’s tips, I recommend checking this guide for all LightBurn settings for a Sculpfun laser: Setting up the software - Diode Laser Wiki
Thanks, problem solved. New installation, reset all settings, wrote new gcode-config (there was an error), now it works.
