My Ortur 5W is back on and working correctly. The Laser Tree 10W Module is engraved “80W AA24V”, that was the first thing that I checked. I got the new Power Supply from Amazon too, so if it don’t work I’ll return it with the 10W Module.
Thanks for all your help.
I was referencing the item description when I stated 24V 2A. I’ll assume that’s more correct than the 80W marketing verbiage.
【Easy to use】Wavelength: 450nm, Input: DC 24V 2A , Power adjustable: Support 5V PWM modulation, Input port: XH2.54-3P socket ,control line installation method: pluggable.
This is the same stated VA as Ortur’s LU2-4 5W even though that’s a single diode model.
