No sé activa diodo láser con mks dlc32
I have a problem, I replaced an mks lts v1.1 with an mks dlc32, the detail is that everything works but it does not activate the laser, I have a 10 w diode laser, with 12v gdn pwm ports,
Testing with the previous card the laser module works correctly, but with the mks dlc32 it does not activate the laser,
Could you help me? I think it could be a parameter that is not active to activate the laser.
MKS DLC32 can work with several firmware’s. The firmware are you using is for Laser engraving?
What pins are you using, and are you using a separate power supply to drive the laser directly?
