I am trying to manipulate a straight line and make it curve. I know how to node edit shapes, but it is not letting me convert the line to path and node edit.
Any ideas?
Any ideas?
Do you need to convert to path them first?
Hover over the node and press S key on your keyboard. It will spline the node. D will delete the node, I will I set a node and C will create a corner.
If you draw a line, select it and select the âNode Editâ tool, you can hover over the line and hit the âSâ key to make the line smooth. Is this not working for you?
You can see this in action in the following video (2:20) titled âNode Editing, Perforation, and Flood Fillâ from our youtube channel:
Other âNode Editâ options are described in the documentation here: https://github.com/LightBurnSoftware/Documentation/blob/830efd7e86526a3eb032fec25383f6ec66040fea/CreatingNewVectors.md#node-editing-tool-
I am not sure what pa is?
Sorry meant path
Thank you Rick. I was selecting the line and then going to the Edit menu to convert to path and it wouldnât. I didnât know about the pressing node edit and s. It worked great! Thank you again.
Glad that helped. Yes, a line is already a âpathâ so that is why you see the âConvert to Pathâ grayed on the menu.
