i have a recent problem when trying to use node edit. I believe it happens since updating to 1.4 mostly. At times i can’t edit nodes. I have checked whether my shapes are “path”, or grouped (and if they are i ungroup them till none is grouped) but still face the same problem. I can move the nodes but i can’t break them or delete or anything else. There have been times that i save the project, reboot lightburn and it does the job but on very rare occasions. Anyone else, or just me?
I will once it happens again. So far every file works after a number of reboots. For example, i was working a project when i opened the topic and until you replied i closed and opened lightburn 3 times. The third one worked just fine, just like that. No other settings, just selected node edit. It also happens regardless pc. I use an acer and a lenovo windows 10 both, same thing.
