Non ritorna all'origine dopo la lavorazione (Does not return to origin after processing)
Ciao piacere sono Giovanni, ho un problema con il mio laser Ruida dopo aver terminato un taglio non ritorna all’origine da dov’è partito e non ricordo come si fa a reimpostare com’era prima. Mi potresti aiutare?
Hi, I’m Giovanni, I have a problem with my Ruida laser after finishing a cut it doesn’t return to the origin where it started and I don’t remember how to reset it to how it was before. Could you help me?
For help, it’s best to post in the category that most closely represents the type of behavior that is causing the problem.
I have moved the conversation from private to a public category so other community members with similar experiences can contribute to the solution here.
For Ruida controllers there’s a setting to select the end point of the laser engraver after the engraving. I will attempt to search for it but here, someone with faster hands might deliver it before I do. :slight_smile:
It’s changed in Edit → Machine settings
