Hey y’all, so I’m fairly new to this program and I’m not sure whats going on. Attached is a picture of the pattern before and after uploading into Lightburn. The scaling looks correct but it completely scatters everything in the PDF. I’ve tried opening it up in inkscape and it makes everything one solid picture, unable to be rearranged or sections removed. Though I havent had this issue with other PDFs before, I’m sure this is operator error. Any tips or tricks? Thank you for your time.
How is the PDF being generated? I haven’t seen behavior quite like this. It looks like some of the shapes are likely to be unclosed but that wouldn’t explain some of the behavior.
Are you able to share the pdf file here? May need to add .txt as an extension.
