doing material test on flacon 2 22w
using a falcon 2-22w and the the material test in lightburn, nothing is showing up on the board. whih is 1/2 inch pine wood
…and the settings you used are?
Can we get a screenshot of your material test window with your settings?
You should be able to make a campfire with this. @Dskall is asking the right question. We need to see what power, speed, and units selections you are using.
yes using .025mm plywood
That seems unlikely, as even the top layer will be thicker than plastic wrap: 0.025 mm = 0.001 inch = 1 mil.
As @MikeyH points out, we need more information to figure out what’s going on.
How to take screenshots:
