I have been working with the Norton method for a while now and can engrave pretty well on ceramic tiles, glass, and slate. Any have any experience with Norton Method on marble? Theoretically, the chemistry should work and the black titanium oxide should fuse to the marble and produce the same effect but I haven’t try it yet. Any help appreciated.
Hi @JerryMou
You’ve probably got more hands-on experience with the Norton method than I have at this point, so I wouldn’t want to overstate this.
My only caution would be that marble is mostly calcium carbonate rather than a silicate/glassy surface, so I’m not sure the same “fusing” mechanism will behave quite the same way as it does on ceramic glaze or glass.
That said, it sounds entirely worth testing on a scrap piece. If you do try it, please post the results — I’d be interested to see whether the TiO₂ gives a durable black mark on marble or behaves differently.
It will be interesting to see the results. The tests on marble without aids I have done (on my CO2 laser) gave very inconsistent results and not nice to look at.
