Hello,
I am wondering if using a 2W IR will work for the NWT method?
Anyone tried and how does it compares to regular blue laser?
Thanks
Hello,
Thanks
I do this on my co2 and fiber… Both of my other lasers use a lot more power than you have… People use lower cost visible lasers in the 5W range, I believe, do this.
As a general rule, I think there is a lower power limit to using coatings to create a molecular bond to the glass with any success.
You can buy TiO2 from Amazon. Sprinkle a little on the tile and give it a whirl.
Good luck
If the laser module has a fan on top, or air assist is used, the dry power will go for a whirl. You will need to add the TiO2 to a binder, like wood glue or white acrylic paint.
