Hello there,
i just bought my Sculpfun S10. I’ve been practicing with Light burn a couple of weeks and today i plug it for the first time. I have downloaded the CH340 as a read in the forum. I have a problem as you can see in the photo. When it prints a circle, this happens. Can anyone help me because i am a nubby to all that. Finally i would like to know if the GRBL-M3 (1.1e or earlier) is right fot this machine?
Thank you
Stelios
check 4 belt tension, both axis cause i don’t understand the orientation of this engraving
Likely not, just GRBL should do. In the Console window, enter $I and it will display the build info. I am betting you will see 1.1f or maybe even up to 1.1h listed. I just bought the Sculpfun S30 Pro and it functions with GRBL, no added letters.
Thanks! I was checking the belts and a saw a loose screw at the one side of the inox bar. All screws needed to be tighten. Fixed!
Go through the guides here, they should get you started
The questions you had are also answered there, as Mike said, don’t use grbl-m3, use “grbl” as laser type. Optimal settings for your laser are listed in the wiki.
