Machine has been running great up until last night. All of a sudden the values we have been using religiously are not returning the expected results.
have tried switching between $30=1000(our usual setting) and $30=255 . also ensured that the S value in LB matched this setting.
When turning the laser on manually it fires.
Able to make the laser test fire at low percentage and focus
If I set the power to 100 and speed to 1 I get a nice black line (picture attached) but it seems any other setting isn’t delivering what is expected (usually 15mm/s and 80% power)
Tried changing the LB setting from C02 to Diode (mm/s to mm/min) no difference
checked all the wiring and connections last night and no issues
Normally I am able to get the answers I need from the forums but I am stumped!
That’s too bad. Probably got hopeful when you found the lens dirty. Probably a good tim to talk with the JTech guys. Heard they’re pretty good about support at least.
