In that case, please do the following:
Use the .dxf file (Calibrate Axis File.DXF (43.2 KB)) to cut on the the material of your choice. Ensure that the model is placed such that X on the model is aligning with X axis of the machine.
Measure the X and Y lengths
Edit - Machine Settings - Calibrate Axis
Calibration Axis - X
Requested Distance - 25
Actual Distance - ________ ( Measured X length, just number will do no need of adding units)
Click Write
Calibration Axis - Y
Actual Distance - ________ ( Measured Y length, just number will do no need of adding units)
Click Write
Try cutting the same file once again and check the measurements,
If it still needs fine adjustments repeat steps 1, 2 and 3.
OR
if it is perfect, try cutting a different geometry to check your results.
