Hey gang! I need your help.
I want to engrave a photo on wood and I have to set a minimum and maximum power, except that the minimum field is not highlighted so I can’t write anything. I prepared the image with ImagR.
What should I do to correct this issue?
Thank you for you precious help!
I’ll assume you’re using the Ortur LM3 in your profile which is a GRBL machine.
GRBL machines do not have min power as an option for anything other than grayscale image mode.
What is it that you’re trying to achieve with min power? It’s likely that you won’t actually need it and can accomplish what you’re trying to get to through other means.
ok, thank you for taking the time to answer me.
