How do you swap pins?
“that was it - the RA2 adapter cable for the Ortur has the middle to pins swapped with respect to that of the Ortur rotary extension - swapped them and things are working properly now!”
this means the wiring in the cable has the center 2 pins swapped
You need to undo the pins on the connector and swap them
How do I undo them? Do you just pull on the wire?
Cool. That is simple enough. Thanks Gil.
Suggestion:
Take pictures before
In case you have to go back you have a visual reference on cable order
Very good idea!
