all of a sudden i don’t know if it was after updating lightburn but nothing is centering. and now the laser is hitting on the right rail even though i have it sized to fit in my work space
It apparently has limit / home switches, so does it home correctly immediately after being turned on? If not, did that recently change?
Are you using Absolute Coordinates
If you are engraving, have you positioned the pattern so that the overscan region on either side fits within the platform limits?
If it happened after update, I would try going to file> load pref backup and choose one before your update.
