After going to the 1.2.04 upgrade my laser shows up in device settings but not on the tab next to Library. Everything is working fine just noticed this.
Check that the Laser window is enabled in the Window menu list. If not, enable it. You may have also moved the window onto a different dock position. If so, you can move the window back to its previous location.
If you still can’t locate the window you can do Window->Reset to Default Layout and you’ll revert to the initial layout.
Yep it wasn’t checked, all set thank you
