Noticing more power needed on xtool D1 Pro 20w?
After the upgrade to 1.5.00, it seems like the laser needs more power to do the same tasks. Using my librafy for the xtool D1 pro 20w, I need to run it again to get close to the same depths and results I did before. Any ideas? Lense is clean, and all other factors are the same. Just need much more power to do the same thing.
Example, 1/4 plywood burn medium was 2200 speed, 25 power. Now, I am up to 40 % power and it is still not enough.
Check the S-settings max in the Device Settings window.
