Hello, I attempted to use offset fill on a complex design and it caused the lightburn software to freeze up when trying to create the offset fills. This occurred both on the preview and when starting the job. Preview hangs at 20%, job start hangs at 10%. Only way to workaround is to force stop the software and reopen. Regular fill works fine. I can imagine there is significantly more rendering required for offset fill, just wondering if there is a way to tell if an image/project is too complex to attempt using that feature?
The issue was the file I was trying to use was way to complex to try and use offset fill. So cockpit error lol.
An error seen by all, I assure you.
I am no exception.
