Offset fill freezing Lightburn
Creating a pattern using Lightburn 1.4.03 with my Sculpfun S30 Pro Max 20W, I use Preview to see how long the burn will be. All too often when I go between fill and offset fill the application freezes and I have to force quit and go back to ‘regular’ fill. I cannot use the cancel button either. Nothing works.
Any thoughts as to why and how to overcome?
Offset fill has a pretty specific use case. If it’s a complicated pattern, it would take a long time to try and generate the offset fills for preview.
I had the same experience. It doesn’t actually freeze but takes a while. Maybe go into edit> optimize shapes and get rid of a few hundred useless nodes to speed things up.
Thanks Dskal, but I’m so new here I have no clue as to what you’ve written. LOL! I’ll see if I can play around with it at your suggestion but will probably stick with regular scan. Thanks for the reply.
