Offset fill quality
Why are the results so different when using FILL vs OFFSET FILL? I know the travel pattern is different, but the results are much better with FILL. Any ideas why?
offset fill uses as name says an offset of a shape and repeats it in at the end, hence the actual look. I think it is advantageous for large surfaces, and is primarily a time saving for some operations.
I believe, fill fills to the next boarder on the layer. Offset creates the ‘offset’ and then fills that.
These can be confusing. Check out some of the lightburn videos on using these, it may clarify what’s going on…
