When using offset fill, the program either doesn’t complete or creates moves not in the program.
A picture or screenshot will help us see what you’re seeing.
As the doc points out, however:
Offset Fill is intended for designs with a lot of empty space within graphics, to cut down on the amount of travel time necessary to fill large, hollow shapes. If that description fits your design, Offset Fill will most likely be much faster than Fill Mode. If that doesn’t apply to your graphics, it’s usually best to use Fill instead of Offset Fill.
If you’re trying to fill letters or intricate shapes, Offset Fill is the wrong hammer for the job.
