Offset not right
Offset is not working correctly. Click outward and I get both. Click inward and I get nothing. Click both and I get both.
What version are you using?
It could be that you have overlapping lines or open shapes.
Go ahead and post your LightBurn project file into your reply so we can take a look at what you’re doing.
And if you can show us some pictures of what is going on as well as a description so we can see.
It sounds like the objects you’re trying to offset are open shapes, rather than closed shapes. It’s not possible to offset open shapes inward — even if your shapes are arranged in such a way that you can see by eye what you mean by inward, the software can’t make that determination unless you close them.
Depending on the exact shapes you’re working with, you might be able to use Auto-join, Close Path, or Edit Nodes to close them.
If you can share the project file, or a screenshot of your project, we may be able to make more specific recommendations.
You can read more about open vs. closed shapes here:
