Offset prob on Print and Cut
Figured out Print and Cut, got 3 nice aligned jobs. No pointer offset going on here or anything.
Then I tried this one. It all LOOKS right, but I did a trial run with no beam and it runs about 20mm to the right and maybe 10mm low,
The only thing different is the first target is top right and the second lower left. But that shouldn’t matter.
Reselected the P&C targets and realigned with scale- same outcome. Wrong place.
This is super bumming me out. Making a little Halo Master Chief was great, but I was REALLY looking forward to Mando
Any ideas? I started with doing Trace part of it was following the wrong feature so I manually traced fixes and did Node Edit to trim it all up, but then while it was a series of lines with coincident endpoints, it was still not a closed shape and even jumped all over and ran some segments in other directions. Anyhow, finally got it to close- I don’t see how that difficult design history would change anything anyhow.
mandalorian-the-tragedyc.lbrn2 (520.5 KB)
Try changing the order of target selection. If that doesn’t work, try reorienting the work material and try again. I don’t see anything in the file that should pose a particular challenge.
