Having a issue wit line offset in lightburn. I got the offset where i wanted for the speed/power i use for NWT It looked great. Then I switched to doing painted glass different power/speed. Set the line offset for that speed it looked great. went back to doing NWT and the offset is waaaayyyyyy off now. Now that I have 2 different speeds set up do I need to fine tune the first speed i did?.. could it be when opening light burn it did not communicate the offset settings to the laser?? im useing a black n blue board and 1.w apeture laser if that makes any differance.
Did you enter a range of the low and high speeds… if you do this, it should compute for values in between…
Generally the amount increases as you increase the speed… mine has a few in it…
This is an old one… it’s been adjusted since then, but it’s the general idea…
Good luck
