Offset Tool hangs when using on a circle from a circle array
MacOS Pro M1 Sonoma LightBurn 1.6.01
After creating a Circle Array, I want to set an offset on the resulting circles.
The Offset tool just hangs LightBurn and I have Force Quite LightBurn.
I figured out what was happening.
I did not understand fully on how to use the Circle Array.
I ended creating probably about 10 circles in the same spot then that was duplicated one I did figure out the circle array tool.
Welcome, Gene. Glad to hear you got sorted and were able to produce what you were after. To assist a tad further, the following is worth review, if you haven’t already:
