All of the sudden, any projects are inverted and rotated. That goes for old projects as well. I try to go to the “Move” tab to reset origins, but the entire box is greyed out and I can’t change anything. I have tried reinstalling lightburn but nothing works. The laser works, its just everything is inverted. Any help is appreciated.
You have your device origin set differently than when you created the projects, and what is correct for your machine. As an aside, reinstalling LightBurn will almost never fix anything. The LightBurn configuration is stored in a different location so that it’s not touched during a reinstall, etc. for upgrade purposes. Removing and reinstalling LightBurn will still have the exact same configuration as before you started due to this.
This document should assist you in getting it set properly again:
