New to laser engraving loaded all the files from usb everything looks good on my end the laser will frame what im trying to engrave but won’t engrave it if anyone can help thank you
99% of the time, it’s a focus issue. Fibers have very critical focus points and being a few mm off can result it what looks like a failing machine.
Did you load the markcfg7 file that came with your laser? This loads all the information about the control board along with your supplied lens correction.
