raine
(Raine Lightner)
May 18, 2025, 12:30am
1
I’ve using Lightburn on a Macbook Pro M3, connecting via Lighbridge and tried USB, but result in he same thing occurring.
Anyone else experience this?
Thanks!
ednisley
(Ed Nisley)
May 18, 2025, 12:57pm
2
Other folks with similar problems seem to regain happiness after replacing the machine’s failing 24 V power supply. The controller may be failing, but the power supply is a much less expensive part and it’s worth starting there.
Some earlier discussions with similar or more dramatic symptoms:
I need some help. I have a used china blue & white 50 Watt (actual ~40 watt) that I just bought second-hand. While aligning the mirrors and making test cuts, I’ve recently started getting an alarm LED on my stepper motor drivers (sometimes only one axis, sometimes both, other times no alarms).
I’ve looked at the manual for the driver (2DM542-N) and this is what the LED alarm indicates: Error occurs when the motor coil current exceeds the drive’s current limit.
Can someone explain what this mea…
I have had my omtech for about a year now and this issue started about 4 months ago. It was running a job and stopped mid job. The screen began to flash and it kept trying to reset in between flashes.
I contacted Omtech but same as anyone else there were no help. They had me troubleshoot and remove the pins for the X and Y axis. With removing them the machine would power on and reset but would not home. It would crash into the top right corner as if it was trying to home but can’t. The to…
First of all, good morning everyone, laser users, LB fans, technicians, and OZ… always a pleasure to come on the forums!
Well, basically what the title says… im using my machine and for some reason, the screen begins to blink, and the entire system resets. Oddly enough, even when I have the machine on, and am not currently using it, the error can occur and the restart happens as well.
ive checked all the cables… the power cables from the wall to the voltage regulator, and from there to the la…
As a rule of thumb, replace the supply with one having at least 50% more current capacity, as the OEM supplies are grossly under-specified for the actual maximum current to all the motors / lights / controller / valves in the machine.
jkwilborn
(Jack Wilborn)
May 18, 2025, 1:09pm
3
Do you send or start ?
Send transfers the entire file to the Ruida, start , will send some data start the machine before the file transfer is complete.
Does the file load completely?
system
(system)
Closed
June 17, 2025, 1:09pm
4
