Disclaimer: this seems to be a hardware issue as behavior is identical with Lighburn and EZCAD2
I recently acquired an OMTech 50W Raycus machine with a seemingly genuine BJJCZ controller.
The machine connects. The galvo head is operational. The RED LED from the laser source functions (no way for me to toggle it, it’s always on). LED1 on the BJJCZ board lights up when outputting. But the fiber laser does not output.
Finally after ~30 minutes and power cycling a dozen times the laser came alive and starts outputting. The next day the same process would begin again.
The seller suggested a defective source and sent me a new Raycus unit but the same behavior continues. After a couple dozen outputs, power cycles, and reconnects the laser begins outputting.
I’m questioning my BJJCZ board and wiring now. I’ve got a new DB25 cable arriving tomorrow to replace the one connecting the controller and source as I tested intermittent continuity on pin 16 (LASTERST0 on the board). Regarding the 24V PSU the voltage tested nominal but I happen to have an identical Mean Well model so I’ll be swapping that too.
I will update tomorrow when the cable arrives. Open to any other suggestions.
