Omtech+ camera selection causes lightburn to crash
Every time I select SHUNCOM camera Lightburn crashes.
I have an OmTech Polar+ and have never had cause to add a camera.
Now I need to use it - I cannot load it.
I have checked Mac Privacy - Camera permissions are allowed for Lightburn.
Tested that the camera can be seen by my Macbook Pro by opening ‘Photo Booth’ app and choosing it. It takes images OK.
The camera is connected to Macbook via USB cable (short 1 meter length) (USB3 socket)
In Lightburn_PreRelease 2 I select Manage Camera - Add New - USB - SHUNCOM and then Lightburn crashes.
I did once manage to get through Camera Calibration, to 87% but as soon as I selected ‘Finish’ - Crash!!!
The Polar is connected via Ethernet so that only the camera is dependant on USB.
I run Mac OS12.7.6 and therefore
I cannot upgrade to the latest Lightburn as my mid 2015 Macbook Pro cannot be upgraded to OS13
JohnJohn
Please edit above post on Line 8 after “USB - SHUNCOM”
add the words: "I get a quick flash of a screen saying CONNECTING "
I cannot edit this due to permissions.
Thank you.
Update!!!
I have now had 100% success.
3 points that do not seem to be mentioned anywhere:
  1. Connect the camera via a powered USB hub.
  2. In Lightburn 2.1 - Settings - Camera make sure that the 'Enable Camera Hardware Control" is NOT selected.
  3. In the same settings box select “Fallback” for Camera Selection System.
Then the job is a Goodun!
Loverly Juberly…
