Hello, for some unrecognizable reason my laser machine is starting to CUT incorrectly recently, changed speeds from 15mm to 10mm at 65% POWER and still the same issue, it gets worse ofter this point, it goes perfectly and then at one point it starts to cut “off”
Seems like machines “Centre” is of or something? Checked belts, they are OK, machine runs ar 16Ma, at first thought might be file problems but no, keeps doing this in almost every file, changed even from USB to Ethernet, still no solution.
