Please help.
I have had the laser connected with usb and no problems.
I need it connected via ethernet. I have read and followed all instructions for connecting via ethernet.
ip address is set on laser (actually same as original settings when bought) as my network is the same.
Currently laser is connected to laptop via ethernet. Ip on laser is correct to network and no other device is using same ip. Loightburn still says no device
Thanks you Tony
I thought it would not connect?
The Ruida machine console will indicate if it’s connected, hardware wise. It has internal LEDs and a ‘Lan:’ that is off or on in the console window.
Can you see the ‘device’ on the network?
Your network is the same as the Ruidas default?
Did you do the add device wizard again?
