Hi All
A little help if you don’t mind, I set my OM Tech rotary system up today, does anybody know the “steps per rotation” for this machine ?
Also, what is “mirror image to rotary” for ?
Hi All
Did you ever figure this out? I’m in the same boat
Yes, I set the diameter to 100mm and the drew a100mm x 10mm rectangle, I then put 3 layers of masking tape on the glass and burn it, it was set to 10,000 steps and it over shot the mark, I finally ended up at 6,800 and it all works fine now, try it at 6,800 it may save you some time.
