One axis not going perpendicular to other
When I try to burn a simple rectangle, it comes a bit skewed. The sides are not perpendicular to each other. The size of the rectangle is 205mm wide by 305mm hight. I have tightened the belts on both axis and I dont notice any skipping of the belts. The Laser is Longer RAY5 and is fairly new. Has anyone faced this issue? What can be done to resolve?
Are your rails square to each other?
Can you round the corners of the rectangle and show what that output looks like?
Your gantry is most probably not perpendicular to the side rails. Measure distance left and right between gantry and front of the frame. If not perfectly equal, loosen a setscrew in the pulley opposite motor-side so that you bring the gantry in a perpendicular position and lock the set screw. Do a check with a 100mm square. Measure the diagonals with a calliper. They should be equal within 0,1 to max 0,2mm. The square that you cut out should fit in any direction when you did it correctly.
Ok trying this now.
There was a 2 mm difference between the front of the frame and gantry comparing left and right!!! … Took a while to fix this. But this seems to have fixed the issue. Thanks!!
Here’s a nice way to test the squarenes:
