Online PowerScale and Interval test file generators I created
Hi
I’m new to laser cutting and light burn, and I’ve been playing around with the Lightburn XML file format, and created a few online generators to create test files for power and scanline intervals and wanted to share them.
You can find them here https://o2creative.co.nz/laser/
Let me know if you find them useful or if there are any bugs/errors in the files, Also let me know if you have any suggestions or ideas.
Glenn
Hi Glenn,
thank you very much for your work and for sharing it with us. I am in the process of testing your generated files and it looks very promising and useful to me.
:+1:
Hi Glenn,
Great tool, thank you very much, I was in the process of doing something similar manually, I’ll test it soon.
A suggestion, for people like me using a diode laser with speed in mm/mn, could be a selector mm/s or mm/mn will be great.
Hi
I’ve added in the option to enter in the speed as mm/min
Hi Gleen,
Thank you for the generator improvement, works fine. Great tool.
Antoine
This is really nice! Can you also add inches/min for us imperial users? Thank you.
These are amazing Glenn :hugs:, thank you so much for the work @glennwilton
What might be an idea, is the ability to upload / add custom shapes or images? We for instance had to do tests for a client with power gradients on engraving their logo.
