Only using half the Y axis during engraving
I am using the sculpfun s30 pro max with the x,y expansion. Since the new update the machine only uses half the Y axis but will use the entire axis with the jog buttons. The correct work area is in the settings from before the update. How can this be fixed because this has stopped me from being able to use lightburn
What happens when it reaches the half-way mark?
You need to change the firmware as well. See here:
