Hi,
The ruler of my laser does not match the onscreen ruler. For example onscreen the laser is set x-0 y-0 but in fact my laser does not stand in that position but x-5 y-6 is it possible to correct it?
Hi,
In fact the virtual position of the laser is incorrect.
When I move the laser 100 mm to the right it stands on 150mm on the actual position. On screen it stands on 100mm.
And you’ve calibrated your stepper motors?
Uhm no I did not, were do I do that. I can only calibrate the actual distance or any deviation so 2 cm is 2 cm
Like the example the motor does move the correct distance its the startinpoint onscreen is 0/0 but there is no way my laser van start from 0/0 due to its housing I dont expect any laser can. I need to point out that the laser is not on that position but 5/5. Its full functional that not it I just want the physical ruler to match on screen
