Morning all,
Thanks so much for the responses I think it’s conclusive. Stable connection = hardwire to the PC! I’ll give that a go over the weekend.
@adammhaile thanks for the response. I also have a CNC machine and use Vectric’s VCarve Pro. It has the ability to cut a line between two vectors which is much easier than having to go into Node Edit Mode, separate the line then remove it and join the other ends. Unless I’m missing a trick?
