Open ended slots
Hello, I am trying to make some open ended slots narrower, they currently measure 3.89mm and I want them to be 2mm. But despite everything I have tried nothing seems to alter them. There must be someone out there that has or is having the same issue. Thanks Bigtent59
Post your drawing or the part with the problem here (lbnr2), without it people can only guess. By the way, “open ended slots” also confuses me a bit, …send that file.
Have you tried using the “resize slots in selection” feature in LB? It’s under the tools tab and should work for that if I’m not mistaken.
In order to use the resize slots/tabs tool, you can only have four nodes in the slots and four in the tabs. Turn on node editing and see what your slot has. Delete some if you have more than four.
