When I open an existing file in Lightburn 1.3.01 / Win11 on my laptop, the Open Project window is in full screen mode. I had extended the window to full screen previously to see icons in large size.
Now, I’m unable to bring this window back to a smaller size. The workings inside the window itself are fine.
Tried killing LB and restarting / restarted computer as well
Moved the mouse pointer to the far edges of the window and scroll the window back - doesn’t work. The pointer changes icon to the double arrow, to show movement mode is enabled.
Right click on the top bar for the window menu (Restore / Move / Size) doesn’t work.
Close the window and open it to see any reset, but no luck.
Stuck with this window in full screen. Any ideas to get it down to size? I am able to function with LB normally in all other ways.
thanks, still no luck with ‘reset to default layout’ option.
have also tried resizing the main window to a smaller size and then using the new file (ctrlO) option. still opens the window full screen and can’t resize.
this is the full size screenshot - it spans the whole screen of my laptop. i have tried everything that i know to resize this window - including grab the bottom corner where the resize triangle dots are - but cant seem to make the woindow budge
not sure what you mean - the window itself works fine, just cant resize it.
Jeff, when I right click on the header, the restore option is greyed out. It shows up for a brief moment and then greys out before I can do anything. Only Move, Size come up and they don’t do anything. Close works, but then back to square1.
