Openbuilds Black Box X32
Upgraded from 4x to X32. Lightburn supports 4x. Issues with X32. Multiple areas. Communication. Motor. Limits. Homing. Uses grblHAL. Suspect incompatability with Lightburn. Any experience with the X32 contoller? Might there be Lightburn update in the works? Thanks.
https://www.grbl.org/what-is-grblhal
Looks like it is still stinking new, but has potential.
For a start, do you have all the GRBL $$ settings for your machine entered? Does the meaning of them match your old controller? Communication suggests the PC I/O port settings do not match the controller. Sounds like you turned your laser into a project machine.
Greetings Mike, and all those following this thread. Yes, I do like to tinker, and I have a project machine, that now only resembles the S9. Many of the “upgrades” are sourced from OpenBuilds.
Again, patience and attention to detail are valued over the whine. And I find myself at times in the whine camp. And appreciate the forum’s consideration.
This weekend’s journey with the X32 started at square one. Updated the usb driver. Followed the X32 documentation to the letter. I found I had missed the “Flash” step. Replaced limit switches with Open Builds components. Found that the X32 uses positive coordinates, and researched Lightburn documentation for the work around. Setting feed rates in $100, $101, and $102 for belt drive, GT2. And per documentation, $5=7 (4x was $5=0).
All is now well, and the maching is singing.
So, although the original S9 5 watt module is working well. I want more. Sights on the 20 watt range.
I had a boss ask me when I bought my first car. He asked, “If you wanted a fast car, why didn’t you buy a fast car?”
Hey. I like to tinker.
Glad to hear it. You ever get your fast car?
